Howdy Gents!
I've got a Chevy Volt that I'm playing with. One of the things I'm playing with is the oil and filter. I figure this is the place to post my results.
I put about 2,000 miles on the engine for this filter. (The Volt is an electric car that also has an engine). I'm running Pennzoil Ultra Platinum 5W-30 with a can of Liqui-Moly Ceratec.
I'm using a MicroGreen 200-6 filter (I replaced it with a MicroGreen 300-6 oversized filter).
Here's the filter with the magnets I put on it:
I have two FilterMag SS300s on the side, and two magnets I pulled from a hard drive on the end.
The filter looks to have a silicone ADBV:
And, since y'all seem to care, nicely cut louvers:
Now, as many of you know, the MicroGreen filters have an added 5 micron filter that takes some of the oil, and filters out stuff that is over 5 microns or so. Here's that:
And the filter looks good (note: Too few miles to stress it):
Here's an observation: I see no evidence that the Ceratec was filtered out by either filter. And, the oil still has the look of an oil with Ceratec in it. So, the Ceratec really isn't filtered out by this filter. Makes sense - Liqui-Moly says its particles are 0.2 microns, MicroGreen says its filter filters down to 5 microns.
Here's another observation: The bypass filters in the MicroGreen filters are no longer PTFE (aka Teflon). They look like some sort of pressed pulp or fabric.
Now, I wanted to know whether there would be any significant magnetic detritus in the filter. There was:
Now, here's the interesting part: The above pictures were taken AFTER I cleaned the container with brake cleaner. The brake cleaner did NOT dislodge the iron filings.
When I removed the magnets and sprayed the inside with brake cleaner, the filings stayed in place.
When I took another strong magnet and wiped it past (from the outside), the filings did not move.
The ONLY thing I was able to do to move the filings was to wipe them with my finger, or with a paper towel.
The filings were so small that I couldn't see or feel any individual particles. They just looked like a black paste.
So, here are my musings:
1) Magnets do pull magnetic material out of the oil.
2) There is a significant amount of magnetic material even with a MicroGreen oil filter. By significant, I mean enough to see.
3) The magnetic material looks to be really, REALLY small. It looks like a black paste, and feels like one too. I couldn't make out any individual particles. I bet they're all smaller than 5 microns or so.
4) Once the particles are stuck to the inside of the filter, removing the outside magnet, spraying with brake cleaner, or moving another strong magnet on the outside of the filter cannot move the particles. (This, quite frankly, surprised me).
5) Ceratec and MicroGreen filters are compatible.
6) The MicroGreen 200-6 works as a normal sized filter for a 1st generation Chevy Volt.
7) The MicroGreen 300-6 works as a oversized (a bit longer) filter for a 1st generation Chevy Volt.
8) The Longacre-Billet Oil Filter Cutter that I used to open the filter is a really slick tool!
9) But, it leaves razor sharp edges that can cut you bad. (Don't ask.)
