https://www.bgprod.com/catalog/drive-line/bg-ultra-guard-full-synthetic-gear-lubricant/ has anyone ever used this brand gear oil or know its quality compared with other well know brands. I was thinking about using it in my Toyota Tacoma, based on the prices of the recommended 75w85 gl5 by Toyota I think im going to use a 75w90 instead that is readily available and at least 1/2 the cost of 75w85 oil, even tho the MPGs may suffer slightly? but have a bit better protection, the trucks a D. Driver and I don't tow, just light loads occasionally. Ive used BG DOT4 brake fluid in the truck and it seems to be a good product im assuming the same will go for the Gear oil.thanx if anyone has info on it.
