Thanks for those informative links.
The Competition for Metal Surfaces, and the Machinery Lubrication article both stated that point. OK, so until I get some evidence to the contrary, I can assume this is most likely true.
The Results article (well, it was powerpoint notes, not an actual article) was interesting. I tried keeping track of which oil (with which additive pack) was being tested in each test, so I might have gotten things mixed up, but if I was on target, it seems like the oils with supplemented additive packs did better than just the base oils with small additive packs, but each one did better at one test or another. So it really does come down to balance, when deciding how much of each additive to blend in.
