Originally Posted By: HerrStig
The sensor doesn't transmit unless the tire is moving. Does the "bomb" duplicate that.
My experience is the TPMS sensors do not have to be moving to transmit.
I have 5 wheel/tire sets sitting in the corner of my garage - they have TPMS sensors mounted and registered to my 2013 Toyota Land Cruiser.
I also have 5 wheel/tire sets mounted on my Land Cruiser - they do not have TPMS sensors.
If I start my truck up in the garage, after about two minutes the onboard TPMS display will show the pressures of the set of tires sitting in the corner - no TPMS warning light.
When I drive out of my garage, after about 20 minutes the TPMS warning light will start to blink, then go solid.
Based on this, it is clear that as long as my truck is within range of the tires that have the TPMS sensors, they will be picked up and valid pressures will be sent to the truck - even if they are not moving. And, obviously, if I am out of range of the tires with sensors, the TPMS warning will be set off in the truck.
So, if I wanted to use a "TPMS 'bomb'" I see no reason why it would not work even though the sensors are not moving.
HTH
HTH
