Point being, the 3,000 lbs. is within the truck's GVW and keeps it very well within the limitations of the suspension, tires, and brakes. I could've swaged the bed out, bent the springs over, and put 5,000 lbs. in it instead, but didn't because I want to continue using the truck without a fortune on repairs or alternatively buying a new one. If it was a half ton, that'd have been 1,000 lbs. of gravel. Ruining the truck for a few dollars, or a few hundred, hardly compensates for a few thousand on a new truck.
