Originally Posted By: wag123
Originally Posted By: mk378
Test compression, of the three cylinders you can reach easily anyway.
I will say if it fails a compression test, you can quit wondering about other stuff.
+1
I don't have the tools or knowledge to do a compression test.
You say that you don't want to spend much on repairing this car. A compression test is a
FUNDAMENTAL diagnostic test on a low value car with this many miles and a dead cylinder miss.
Performing an engine compression test is not rocket science. The Internet is a wonderful place to learn new things.
http://www.popularmechanics.com/cars/how-to/a8520/cars-101-how-to-do-a-compression-test-14912158/
And... compression gauge testers are not expensive tools.
https://www.amazon.com/8milelake-Compression-Engine-Cylinders-Diagnostic/dp/B013OL5TBG
If a low value car with a high mile engine flunks a compression test, you would stop spending money and working on it right then and there.
Autozone will loan me a compression tester. Assume I have to put the engine back together (lower IMG, plenum, injectors ) for an accurate test?
