Originally Posted By: clinebarger
Originally Posted By: Rumble
Dug out my paperwork, and I erred with the trans type. Like Max says above, it's a "4L60-E" (GM code MD8, 700R4) series. As to the fluid and filter, I put in a new filter and fluid (Valvoline) 7 years ago with 130K miles. The truck now has 148k, so that's around 18K on the fluid and filter. I can certainly do that again, but if I had the pan off, is there a few solenoids or something that I could replace while I'm in there? In any case, I'll definitely try some AT-205. As to the truck, I bought it new 25 years ago (1992 "Sport" Edition w/350 and posi rear) and it's in excellent condition. So, if needed, I'd have no problem with putting in a new trans, as I'd rather have this truck than a new one. If I can't sort things out, I can surely take it to a pro. Thanks!
A 1992 will have a 4L60/700R4 NOT a 4L60E, 700R4 RPO is MD8, 4L60E RPO is M30. You only have one solenoid....TCC Solenoid.
A leaky TCC solenoid can cause TCC shudder, Though uncommon on this unit as it doesn't take much pressure to keep the TCC apply valve stroked....They typically just stop working altogether.
A engine misfire can cause bucking when the TCC is locked.
The VSS sensor is a common leak point & reoccurring problem with the design, You can install a 1996/1997 4L60E extension housing & VSS sensor & eliminate the issue forever.
Do not use Cork, Rubber, Or Felt pan gaskets, Use GM# 8654799 gasket & torque to 10 ft lbs/120 in lbs.
It actually felt like the engine may have been misfiring a little during highway speeds (40-55 or so). Sort of a slight "bucking" feel is the best I can describe it (or the "shudder" I mentioned earlier). I replaced a leaky VSS sensor a few years ago (and rear seal around the same time). Don't remember what kind of pan gasket I did 7 years ago, but it hasn't leaked. If I open this thing up again, I will use one like you suggested. Is there access to the TCC unit with the pan off? Thanks very much for the info.
