J JZiggy Joined Oct 12, 2010 Messages 902 Location GA May 24, 2017 #1 Hey guys, I have a can of Super-Lube multipurpose #2 grease that I use for all kinds of stuff. Can anyone confirm what is the base type? Is it lithium complex or something else? Thanks!
J JZiggy Thread starter Joined Oct 12, 2010 Messages 902 Location GA May 24, 2017 #3 Yes, can only find stuff like "synthetic" and "has PTFE"
DeepFriar Joined Oct 31, 2013 Messages 1,551 Location Georgia May 24, 2017 #5 It's food grade but I'm trying to cut down on my PTFE's. Too much teflon gives me the runs.
N NJ_Car_Owner Joined Mar 16, 2017 Messages 206 Location NJ May 24, 2017 #6 If you call them they will probably answer your question.
E Ethan1 Joined Dec 29, 2014 Messages 1,700 Location 'murica May 24, 2017 #7 The only two things they really say on the website are that it contains PTFE and it contains NO silicone
E Ethan1 Joined Dec 29, 2014 Messages 1,700 Location 'murica May 25, 2017 #8 I also found a spot on the website which says that it's not metal-based, so that rules out lithium and calcium
A ant Joined Nov 18, 2003 Messages 234 Location Louisiana Dec 31, 2018 #9 The MSDS seems to indicate that the base is Fumed Silica. I email SuperLube asking the question directly, but have never received a reply. Is there a grease compatibility chart that includes Fumed Silica? Is this the same as Silica Gel? What are the pros and cons for this grease base? Last edited: Dec 31, 2018
buck91 Joined Apr 17, 2012 Messages 3,550 Location West Michigan Jan 3, 2019 #10 They told me it's a ptfe thickener as opposed to lithium and the like but I can not verify it wasn't a marketing based response.
