Miles on Civic- 473,349
Miles on oil- 10,071
Amsoil AZO 0w-30 oil
EAo36 oil filter
Dual Filtermag CT-3.2
Golden Eagle magnetic drain plug
One quart of makeup oil
Blackstone Labs; Harry, silicon bumped up, but not enough to earn a mark. Wear metals are still in good shape, so we aren't terribly concerned with dirt infiltration. It wouldn't hurt to check out the air filter though just to be safe. Everything else looks good and no measureable fuel
showed up, so this is the first "perfect" report in quite some time. TBN was a strong 3.0, and the particle count read 17/16/14 - cleaner than last time. All in all, we're just glad to see your engine earned a highlight free report at 473,349 miles, Keep up the good work!
Code:
[/code]
Aluminum------------------------4----------------------------4 universal average based on 3,500 mile OCI
Chromium------------------------1----------------------------1
Iron----------------------------16---------------------------9
Copper--------------------------3----------------------------3
Lead----------------------------0----------------------------2
Tin-----------------------------0----------------------------1
Molybdenum----------------------270--------------------------84
Nickel--------------------------0----------------------------0
Manganese-----------------------0----------------------------0
Silver--------------------------0----------------------------0
Titanium------------------------0----------------------------0
Potassium-----------------------9----------------------------4
Boron---------------------------43---------------------------49
Silicon-------------------------20---------------------------11
Sodium--------------------------10---------------------------43
Calcium-------------------------3411-------------------------2146
Magnesium-----------------------36---------------------------143
Phosphorus----------------------655--------------------------712
Zinc----------------------------754--------------------------833
Barium--------------------------0----------------------------0
Code:
SUS Viscosity @ 210 F---------62.2---------------------57-67 (value should be)
cST Viscosity @ 100 C---------10.85--------------------9.4-12.4
Flashpoint in F---------------410---------------------->385
Fuel%------------------------- Antifreeze%-------------------0-------------------------0
Water%------------------------0------------------------- Insolubles%-------------------0.3------------------------ TBN---------------------------3.0
Particles for ISO code 17/16/14;
>=2 microns--2,222 particles
>=5----------823
>=10---------227
>=15---------88
>=25---------21
>=50---------2
>=100--------0
Note- Silicon value a bit higher due to a valve adjustment.
