Originally Posted By: Lubener
Originally Posted By: L_Sludger
Follow the oil cap for your viscosity. I bet a thousand dollars that 0w40 is not specified.
My guess too. Don't know why someone would use a weight that is not specified and then wonders why things aren't performing well.
WHY, you ask---?
because the mo's who wrote the 0-20 spec in the manual are the same mo's who also wrote in the manual it is perfectly fine for the engine to burn up to 1 qt/1000 miles.
THAT IS WHY
Steve
WHY, you ask---?
THAT IS WHY
Steve
