My high school aged son has been driving our 2009 Cadillac DTS to work, school, and sports practices etc.,pretty much every day for the last 2 years. Most of these are short trips, but some are in excess of 50-60 miles round trip. I bought the car from my grandad's estate after he passed away a few years ago, and it currently has about 60,000 miles on it. It has the dreaded Northstar oil leak (only leaks when the engine is warm or hot, not when it is sitting in the garage at ambient temperatures, and even then does not leak enough to require any top off oil), but other than that is in average to above average shape. Besides regular oil changes, and a new front left hub assembly, I'm not sure much mechanical work or maintenance has been performed. As far as I know all fluids are most likely original.
My wife and I are buzz kill parents and he will not have a car when he goes away to college in August of this year. Unless I make a point to drive it, it will sit in the garage undriven for weeks at a time. My question: Should I make a point to drive it every 3 or 4 weeks (or similar) just to put a few miles on it and get everything up to operating temperatures, or is it ok sitting for a while as long as it doesn't sit long enough to drain the battery? It's under the back seat, so I'd really like to not mess with a battery tender unless absolutely necessary. Any other general concerns for a car that has been driven regularly that all the sudden stops being driven at regular intervals?
Thank you.
Thank you.
