Hello! I have a 2002 Mazda Miata that I currently use as a daily as well as an autocross car 9 months out of the year, once a month. Usually 6-12 90 second runs, as our courses are pretty lengthy and I often have a co-driver.
Now most people consider autocross to be rather light and not too hard on the car, but our courses are typically a bit longer than most, and the car doesn't always get a big break in between runs so I'm sure temps start creeping up pretty high. Miata's are known to run very high oil temps, even like 250F in traffic. I don't have an oil temp sensor on mine but I could imagine on a 4th session in a row at an autoX those temps are pretty high...
Now I've been using Mobil 1 0w-40 magical sauce in it, and it seems to have a decent result. But I'd feel better with something heavier for 5k mile changes. Like a 0w-50 or 0w-60 if that even exists lol
But that may not be necessary. Should I change my oil in shorter intervals? The miata only holds 3.8 quarts as well so oil changes aren't exactly expensive(though they are kind of a pain with the filter location) My main concern is the intense heat combined with high rpm operation that could shorten lifespan for sure with oil that's too thin.
And what oil would you use in this situation and why? I'm interested in opinions.
