A strap wrench that uses a material similar to a seat belt and has an adapter for a 1/2" drive also works good. Crushes the oil filter usually though. It's my go to in hard to reach areas when the filter is to tight for anything else. If it's in an easy area a normal oil filter wrench used near the base of the filter can remove just about the most stubborn filter without damage if that matters to you.
