I got water in one of my fuel tanks my F-150. I washed it down with water after I replaced the pump and the gasket wasn't sealing the pump well. I ended up buying a new gasket that fit better and now it doesn't leak. I started driving it and I thought the rear pump was defective. What I now am pretty sure is I got water in the tank. I took it out and drove and now it has about half a tank. I think I am just going to drive it until it gets down to a quarter tank and fill it back up. Its been getting better as I drive but I will know for sure if its water once I get through this tank I think. I just changed the oil this week with valvoline synpower. Should I need to change the oil after running fuel with water in it?
