As the topic shows, I have a '78 Evinrude 15hp. Background since I've owned it for 3 years -- I was chasing an electrical issue, so I just had all of the components replaced. LAst summer, it didn't get much use... just a few hours, but it ran fine. 4 hours of use this year, and the upper cylinder cut out on me. I pulled the cover and disconnected the wire, and upon reconnecting the wire to the plug, discovered that if the wire sits halfway on the plug, the electrical connection is completed, and the cylinder comes back to life. Insert it all the way back on the plug, and it cuts out.
Again, the coils, wires, and plugs are all relatively new.
Any ideas?
Important edit: this issue is why I had the electrical components replaced to begin with.
Any ideas?
