I have a 40 gallon parts washer I want to add a filter to to filter the solvent before it comes out the nozzle. Everyone seems to use an oil filter relocation kit when adding a filter. I want to use a water filter to filter out the solvent. Something like this https://www.amazon.com/Pentek-158117-Clear-Filter-Housing/dp/B003VT79VA. I like that the housing is clear so I can see what the filter is trapping. Also the filters are large and reasonably priced with a 5 micron rating. I don't know much about oil filter micron ratings but 5 microns sounds pretty good. The solvent I will be using is crown psc 1000 parts cleaner from tractor supply. I want to know if the water filter will work with the solvent and not fall apart. Will the solvent eat the water filter housing or is the water filter housing plastic resistant to the solvent? Thanks
