Originally Posted By: MrHorspwer
TPMS light on. ABS and stability control light on. Obvious corrosion on B+ terminal. Guy only looked to have the truck serviced after it wouldn't pass inspected because of the CEL.
Seems like the owner is the paragon of maintaining his vehicle.
Replacing the timing chain and the balancer chain at the same time is a bit of a head scratcher too. Completely different service procedures. Nothing you do to the front of the motor to replace the timing chain is necessary to service the balancer chain and none of the work at the back of the engine to service the balancer chain is required to service the timing chain.
The balancer chain also won't cause any CEL issues. The CEL is caused by cam/crank sensor corrolation. Yeah, a balancer chain may cause a noise, but not a CEL.
As pointed out in the video, the timing chain and the balancer chain are of a completely different design. They're located at completely opposite ends of the engine. What would be a common cause for both to be excessively stretched?
Lack of maintenance maybe? Play dumb games, win stupid prizes. Don't maintain your vehicle, replace expensive parts.
I agree, wouldn't timely OCIs stop this from happening before 150K miles? Hard to believe a truck that old is worth a $4K timing chain job, it would be going bye-bye if it was mine.
