Hello, new member here.
So I've had this 91 jeep Cherokee that was unfortunately owned by a back woods hillbilly who had no idea what maintenance was, pretty sure he ran straight water in the radiator the time he owned it. I've Been trying to flush it out for the last 3 years I've had it, ran numerous flush treatments in it, did the old school cascade method, pulled everything off and ran a water hose through the block trying to get all the sediment I can out of the thing. Just recently replaced the whole cooling system, pump, thermostat, the whole nine yards. I also threw on a wix coolant filter base and a Baldwin B5134 filter inline with the heater core to hopefully catch the other [censored] that keeps appearing in the system. I noticed the exit hole on the filter has a restricter in it, and it seems they all do. Can anyone shed some light onto what the reasoning is behind this? Seems you'd want as much flow as possible. And can you see a problem in punching it out to gain more flow?
