Found this Youtube channel where a gentlemen does several video tests of Seafoam and various other products, including water, to clean out combustion chambers. His first vidz are on an old Ranger farm truck. He then uses some old lawn mowers. Pretty interesting. From what I could tell, MMO did a darn good job. He also piston soaks several lawn mower engines and tests before and after compression. Bottom line is all the products, including water, remove deposits from a combustion chamber. Check out his channel:
