Yet another M1 0W-20 grade flavor!
by fdcg27
02/25/18 07:40 PM
The Winter Olympics
by BlueOvalFitter
02/25/18 07:23 PM
Enchilada casserole
by car51
02/25/18 07:21 PM
John Force Crashes at Phoenix!
by KneeGrinder
02/25/18 07:11 PM
Need floor jack that can use Pinch Weld adaptor
by MI_Roger
02/25/18 07:10 PM
The new Champ ST9688 is fat like the 3593
by slacktide_bitog
02/25/18 07:10 PM
Do you drink milk regularly?
by Reddy45
02/25/18 07:05 PM
What Is This Symbol?
by BlueOvalFitter
02/25/18 05:29 PM
Can't believe I fixed it
by Stelth
02/25/18 04:40 PM
Cruise Control Set at 55
by das_peikko
02/25/18 04:39 PM
Who here has satellite radio in your vehicle?
by ZZman
02/25/18 04:01 PM
Oil choice for new to me 07 escape V6
by gabriel9766
02/25/18 03:10 PM
Super cleaning windshield
by mclasser
02/25/18 02:36 PM
New WM oil filters...
by rollinpete
02/25/18 01:49 PM
Swapped Out Bunch of Indoor Flood Bulbs to LED ...
by LoneRanger
02/25/18 01:45 PM
Scanner ABS Transmission and Engine Codes reader.
by littleant
02/25/18 01:38 PM
Meijer - Quaker State buy one, get one 50% off
by Bighorn2500
02/25/18 12:50 PM
Anyone own a 3rd generation Toyota Tacoma
by 007
02/25/18 12:47 PM
Best "wax as you dry" type spray wax?
by aquariuscsm
02/25/18 12:39 PM
Any current Edge 0W20 users here ?
by aquariuscsm
02/25/18 12:27 PM
A1ex, Grozd, swc, coronad0, davidsain
64288 Registered Users
107 registered (A310, asiancivicmaniac, Astro14, andyd, antonmnster, AV8R430, 11 invisible), 1750 Guests and 91 Spiders online.
64288 Members
65 Forums
278798 Topics
Page 1 of 2 1 2 >
#4409110 - 05/19/17 09:56 PM Why does synthetic oil last longer?
Cristobal Offline
Loc: In The Region Between
I am posting this question for a friend of mine. He is a retired physician and knows more about chemistry than I do.
Surrounded by ferocious, snarling, & spoiled Poodles!
#4409124 - 05/19/17 10:15 PM Re: Why does synthetic oil last longer? [Re: Cristobal]
Olas Offline
Loc: Manchester, England
It depends on which synthetic and which conventional, but, in general;
Syn can last longer because it's generally 'better' at TBN retention, resisting shear, high temp stability, dirt suspension, and all the other metrics that can be used to quantify an oils performance. It's 'custom built' in a lab.
Conventional is kind of a 'close enough' botch job that will do the job but not as well or for as long.
Cable ties should hold it
#4409137 - 05/19/17 10:30 PM Re: Why does synthetic oil last longer? [Re: Cristobal]
Kuato Offline
Loc: Colorado
yep, and one reason it's so much better is that the carbon chain molecules are all uniform in length. In a non-synthetic you have various lengths; the shorter ones can burn off more easily, the longer ones are thicker and can cause sludge.
Thick vs Thin test: 15k / 43k miles complete
#4409139 - 05/19/17 10:33 PM Re: Why does synthetic oil last longer? [Re: Cristobal]
aquariuscsm Offline
Loc: South Texas,USA
Don't most synths have a higher starting tbn?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 0W20
#4409163 - 05/19/17 11:35 PM Re: Why does synthetic oil last longer? [Re: aquariuscsm]
901Memphis Offline
Loc: Northern Kentucky
Yes the synthetics get a higher treat rate on additives usually to go with the improved base oils.
2012 Chevy Cruz LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4409184 - 05/20/17 12:16 AM Re: Why does synthetic oil last longer? [Re: Cristobal]
CT8 Offline
Loc: Idaho
Define which syn base oil or blend because all syn oils are not equal and gp III oils are better refined than gp II oils which cleaner that base 1 oils due to the higher refining levels [if I worded it properly]. This isn't the 1970's oils anymore.
#4409200 - 05/20/17 01:20 AM Re: Why does synthetic oil last longer? [Re: Kuato]
FordCapriDriver Offline
Loc: Balearic Islands , Spain
I made a post about this a few months back and pretty much everybody agreed that it's just a [censored] marketing strategy.
1975 Ford Capri II Ghia 3000 V6
1988 Ford Escort 1.6 Xr3i Convertible
1999 Peugeot 106 1.1i Max
Finnish expat living in Spain
#4409209 - 05/20/17 02:31 AM Re: Why does synthetic oil last longer? [Re: Cristobal]
L_Sludger Offline
Loc: Ohio
Synthetic oil has better marketing. Type SN oil will be virtually indistinguishable from synthetics over the life of a motor. And it better be, because its three times as expensive as Type SG used to be, and costs what synthetic used to cost!
too many cars and oil combinations to list in 150 characters or less
#4409210 - 05/20/17 02:31 AM Re: Why does synthetic oil last longer? [Re: Cristobal]
Gokhan Offline
Loc: Los Angeles, California
The difference between synthetic oil and conventional oil is the base oil. Additive packages are the same.
Primarily, the reason synthetic oil lasts longer is because its base oil oxidizes (cooks) slower. However, there are different synthetic base oils with different oxidation resistance.
Secondarily and much less importantly, synthetic oils tend to have less viscosity-index-improver (VII) polymers, which helps reduce permanent viscosity loss in used oil as well as polymer contribution to dirt and sludge, which also helps increase the oil-change interval.
1985 Toyota Corolla LE, 4A-LC engine, ~ 269,000 M
Toyota (TGMO) 0W-20 SN synthetic
Mobil 1 EP M1-103 filter, 90430-12031 drain gasket
#4409237 - 05/20/17 04:47 AM Re: Why does synthetic oil last longer? [Re: Cristobal]
SR5 Offline
Loc: Down Under
Yes as Gokhan says, a synthetic base oil be it Group 3 or Group 4, offers better oxidation resistance than mineral base (Group 1 or Group 2) oil. Not that many oils use Group 1 anymore.
Also synthetics have a naturally higher viscosity index (VI) so less polymer VII (Viscosity index improver) is required and so there is less to shear or break down and form deposits. Given the same grade of oil, eg 5W30.
Most synthetics tend to have a better add pack, but this more marketing (put all the good stuff together) but obviously this isn't strictly required and there will be exceptions.
Edited by SR5 (05/20/17 04:51 AM)
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4409239 - 05/20/17 05:04 AM Re: Why does synthetic oil last longer? [Re: FordCapriDriver]
dlundblad Offline
Loc: Midwest
I would have to agree with this as well.
03 Jeep WJ 4.0 197k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 170k M1 0w40 Mann HU818X
97 Chevy Blazer 4.3 138k Synpower 5w30 Fram TG3980
#4409264 - 05/20/17 06:18 AM Re: Why does synthetic oil last longer? [Re: L_Sludger]
Kamele0N Offline
Loc: Slovenia
Well it depends.......modern motocycle SG oils are often more expensive then automotive SN oils....
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4409278 - 05/20/17 06:45 AM Re: Why does synthetic oil last longer? [Re: Cristobal]
Vern_in_IL Online   mad
Loc: IL
My understanding is that Synthetic oils resist shear more, better cold flow characteristics, and can take the heat better. Which is why they are very advantageous in a air cool shared engine/transmission motorcycle.
I think there is more base stock in synthetic oil, (Silkoline pro comp) and the fact that "true synthetic" is made in a lab with more uniformed molecules.
Edited by Vern_in_IL (05/20/17 06:50 AM)
#4409286 - 05/20/17 07:05 AM Re: Why does synthetic oil last longer? [Re: FordCapriDriver]
tig1 Offline
Loc: Illinois
You and everyone else are wrong.
https://mobiloil.com/en/article/car-main...cVsConventional
Edited by tig1 (05/20/17 07:08 AM)
2007 Ford Fusion 221,000 miles
M1 0-20 EP
2017 Ford Fusion 42K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4409359 - 05/20/17 08:47 AM Re: Why does synthetic oil last longer? [Re: Cristobal]
ARB1977 Offline
Loc: North Texas
Magic
2015 Tacoma 4.0L 60K (as of 02/23/18)
Amsoil SS 0W30 / Toyota filter
2008 CRV 2.4L 172K (as of 12-18-17)
Maxlife 5W20 / M1 filter
Page 1 of 2 1 2 >
