I used a clean water bottle to catch the brake fluid coming out of the bleeder as I compress the caliper pistons into it's bore. I've been seeing a lot of DIY videos where the mech or worker does not open the bleeder to let the old fluid out and instead pushes the fluid back into the reservoir but not without the debris going though the ABS pump and orifices.
This is on a 02 Silverado w/ dual piston rear disc brakes. Performing annual inspection and lube from brake sticking issues common in these trucks. This time I am trying out CRC De-Squeak to alleviate squealing from these Wagner Thermo
