I got home yesterday and noticed a puddle of coolant under my Buick (3800 S3). Perhaps a cup, so significant. I put it up on ramps and I could that the leak originated from the general area of the water pump. It was a pretty good leak, a steady drip*drip*drip and it was all over the subframe. I have to top it up once in a while (maybe a cup a month), but no visible leaks until now. My mechanic is out of town until Monday, so I took it to the Chevy dealer. They told me that I needed a water pump (leaking from weep hole) and that I had another coolant leak from the "front cover gasket" (apparently the timing cover). The suggested fix was: "Timing chain and gear set R&R" $1012 in labor, Parts $320 (this includes the water pump, he told me). Does this sound plausible? That's a whole lot of labor, I thought. Even if they're right that seems really steep. I drove it straight to my mechanic and am waiting for him to get back next week. I'll have him look at it. But does that even sound right? $1400 is a good bit, and I just want to make sure that it's even plausible. I don't want to attempt this because it's beyond my skill level and there's not much room to work. But, still, $1000 in labor alone seems steep. There was no time stated on the repair order.
