Originally Posted By: sohccammer427
But then again, as mentioned in an earlier post, didn't the Dodge Eco change specs from a mid saps Euro to a CJ4?
They changed from the oil you are specified to use C3/Dexos II type to CJ4
Wouldn't that shorten DPF life?
One thing to remember Low SAPS, High SAPS, they both still have SAPS which is basically ZDDP. About 25% less for "Low-SAPS". So you still have build up in the DPF/DOC its just the accumulation should be 25% less, its not exactly a zero sum game though. Realistically the only entry way for SAPS to get into the combustion chamber is through crankcase vapor, closed crankcase ventilation. I'm not seeing any oil loss between oil changes in my ecodiesel and no fuel dilution, the oil analysis shows good wear results.
When I see low SAPS oil and 100+ppm iron on an oil analysis you have wonder how well protected the engine is.
In the end I don't care what oil is used provided it gets the best analysis.
BTW, the duramax 2.8 and Ecodiesel are both made by VM Motori.
