My Wife has her Father's 1921, Winchester Model 12 and I'd like to restore it. I know there are some things you should do and some things you should not do to preserve it's value...but I don't know which is which.
I'd like to replace the rear stock because it's got a big chuck of the wood missing (from the upper, top corner that the buttplate is attached to), probably from having been dropped on a hard surface at one time. Should I try and find an original stock or is a replacement O.K.? Should I replace the upper stock as well?
Any other tips, suggestions, etc., on restoring this classic? What's something like this worth in "average" condition?
Thank you!
Ed
Thank you!
Ed
