Heard clunking on way to work. Get to the job and check under truck. Broken sway bar link passenger side. Replaced with Moog on both sides. Seems like oem one had large plastic fitting around bolt which caused bolt to rust away and break. Moog has metal sleeve around it, hopefully it will last longer. I was disappointed that it [censored] out in less than four years.
