I just bought a new 2017 Kia Sportage with the 2.0l t-gdi turbocharged engine.
The owners manual calls for 5w-30 conventional oil, and a 7,500 mile interval for normal service use. severe is 5,000 miles on the same oil.
they also have an allowed viscosity chart, which starts at 5w-30 and also allows 10w-30 and 5w-40 depending on temperatures in your area.
I would like to run pennzoil platinum oil, and with that in mind, specifically 0w-40 which should be just fine on a 4 cylinder turbo engine. I will also be having the change done at the dealership with my oil and their OEM filters, to avoid any warranty problems. I will also be getting used oil analysis from blackstone to support the 7,500 mile interval when the dealer tries to insist that all driving in orlando is severe duty which it is NOT. Orlando is basically the ideal operating environment for an automobile. But, they always try to insist our hot (mid 90's summer temperatures are stressful) climate is hard on engine oil. This is just a ploy to get you in there twice as often.
Anyone else face a similar situation? How did you handle it?
