Just changed oil, did something a bit stupid
Canada
Put in 4 qts, just pouring in from the bottles. That's fine.
Topped it up a bit more with a measuring cup (bottle > cup > motor). I know there's a level on the bottle, it's just always hard to read.
I poured it into the engine from the cup and I realized I forgot to wipe the inside of cup beforehand. There were a few dirt/dust/leaf particulates at the bottom of the cup (the kind of stuff that collects in the trunk). That did not make it into the engine, but whatever else was in the cup did.
I don't think it was much, but just in case, that will be picked up by the filter, right?
I doubt it will hurt anything. I did this at work using a metal 5quart oil can with spout. When car came back in 5k for oil change the Parts Plus filter caught the pieces which were 3 black flecks of dirt. No worry friend
A measuring cup???? Some of you guys are over thinking this! A few ounces over or under filled wont make any difference. I bet you change your drain plug gasket every time too.
Haha, I almost did, but the replacement bolt and gasket I ordered looked a fair bit different from OEM, and the OEM still looked pretty good, so I just reused it.
I'm using a measuring cup for the purpose of tracking some oil consumption/loss.
Thanks again guys, I don't think there's another forum on the web that gets replies this quickly. BitOG rules!
EVERY time. Torque it too.
when its down a qt its used a qt. No need for measuring cups.
Don't forget the calibrated torque wrench for the plug.
Where do we get such men!
ADM. George Tarrant.
Me, too!
Can't remember the last time I changed a drain plug gasket, and even though I own both inch and foot lb torque wrenches, i have never used one on a drain plug. Of course after 50 years of wrenching, my hands/arms are pretty calibrated. LOL
Originally Posted By: exranger06
Meh, that's what oil filters are for, aren't they?
The oil filter will not help if the debris plugs up a return line before it can get to the filter.
As you should. Every fastener in the car has a torque value. Just because people don't know or care about torque doesn't mean it is not important. You can find many examples of quick change oil places that over or under torque drain plugs often with catastrophic results. Using a torque wrench is easy and advisable for most automotive work. I own 4 of them and use them frequently.
I'm always a little paranoid about torquing it a little too far that I'll strip the threads or shear the bolt when it comes time to remove it. I used a torque wrench on the drain bolt for the first time and was surprised that it was spec'd higher than I usually do (25 ft/lbs, my in/lb wrench only goes up to the equivalent of 20 ft/lbs, but it feels plenty tight)
It would have gone straight into the sump. Isn't the filter the first stop after that?
But... the plug *is* a bolt
There is a torque spec listed in the Haynes manual.
Me, too!
Never change it (gasket) unless it's split. Put nice layer of Permatex Ultra Black around the nice clean threads, screw it in and wrench it hand tight. Never had one back out or leak in 40 odd years...
As far as trunk fluff in a cup, no biggie. Either it's heavy and will settle to the bottom of the pan, or it'll get get filtered ... If it's big enough to see readily, it's a filter item for sure
