A week or two ago I topped off the coolant reservoir for my Sienna. I just looked into the coolant reservoir today, and I’m not sure how much coolant I have. I could do with an answer to either of these questions:
(1) How high above the full line is it ok to go, when pouring in more Toyota Super Long Life coolant?
(2) Is it possible that the coolant could be at the full mark, but still not appear to move when I shake the reservoir back and forth?
Background--whey I want to know:
I looked inside the cap, and it was very dry straight down, although with this reservoir, it appears that the “bottom” that I saw was not the absolute bottom of the reservoir---when I pour it, it will go sideways down a gallery. I looked along the side of the resevoir, where you can how the fluid level compares to the low and full marks. From the side, I can see that the level is just above the full mark. But when I shake it, I do not see any wavy movement of the fluid (through the side of the reservoir), like I would if fluid was moving. So I'm wondering if what I'm seeing is just some solidified or gelled coolant, that is on the side of the reservoir.
I could find out how much coolant I really have, by simply pouring in more. My issue is, if it is already at the full mark, I would be taking it higher and higher above it, so I’m asking if this is a major no no.
Hope this makes sense. Please ask for details if you need any clarification.
