Definitely a typo then, probably 7,9 or something, since it lowers as oil is used.
You should ask the lab a confirmation, maybe there are other typo in the report!
Otherwise the oil looks like it has a good add pack. Viscosity is on the upper 40 range, but the oil doesn't start that thick at 17,7 so that doesn't surprise me much. A bit of mixing with previous oil, some fuel dilution (1%)...and it's a 40, not surprising.
Plus it looks like it has its share of heat too! And if it's a shared gearbox + engine sump, then I'd say the oil doesn't look bad.
