The vehicle is a Newmar Bay Star Class A RV. This title is a little misleading. This is a Polaris sample of the factory fill (MC 5W-20). The change is to Kendall 5W-30 but I will take samples of this engine with every change so that's my reasoning behind the title.
I don't find much at all on UOAs for the V-10 but it seems that most RVers want to change every 3000 miles or 6 months. I find it hard to believe that it needs to be done that often so I'm going to see if I can go 7500 miles.
Code:
Miles on lube 1113
Miles on Unit 1113
Fe 34
Ch 0
Ni 1
Al 7
Cu 22
Pb 0
Sn 0
Cd 0
Ag 0
V 0
Si 88
Na 10
K 8
Ti 0
Mo 85
Sb 0
Mn 4
Li 0
B 211
Mg 15
Ca 2068
Ba 3
P 757
Zn 760
Fuel dilution 2.3
Soot
Water
Vis, 100C cSt 7.4
These chassis are built in Detroit by a vendor, who uses Ford components. The chassis is shipped to the body builder who then builds the floor and builds the body. Given the construction process, changing out the factory fill ASAP is a prudent measure.
Code:
Miles on lube 1113
Miles on Unit 1113
Fe 34
Ch 0
Ni 1
Al 7
Cu 22
Pb 0
Sn 0
Cd 0
Ag 0
V 0
Si 88
Na 10
K 8
Ti 0
Mo 85
Sb 0
Mn 4
Li 0
B 211
Mg 15
Ca 2068
Ba 3
P 757
Zn 760
Fuel dilution 2.3
Soot
Water
Vis, 100C cSt 7.4
