Well, I'm not happy with this UOA.
I'm going to pull the tune, run for 5k, dump it, run for 5k and sample w/o changing it, then go from there.
Maybe I should go back to Baldwin filters and RT6.
Filter used: NAPA Platinum
Fuel Additive: Diesel Kleen Silver about every other tank, 8-10 ounces to a 26 gallon tank.
I'll inspect my intake tract and air filter.
I need to find out what is causing the high soot which is likely contributing to the high viscosity @ 100C.
Suggestions?
Code:
MI/HR on Oil 15,592 10,746 21,466 13,893
MI/HR on Unit 143,047 127,455 106,671 85,205
Sample Date 05/03/17 08/10/14 01/13/14 03/05/12
Oil M1 TDT 5W-40 Rotella T5 10w-30 Rotella T6 5w-40 Rotella T6 5w-40
Make Up Oil Added 0 qts 0 qts .5 qts (Filter) 0 qts
ALUMINUM 4 4 6 6
CHROMIUM 2
IRON 47 49 24 34
COPPER 4 3 4 14
LEAD 4 2 1 0
TIN 3 2 2 3
MOLYBDENUM 2 3 67 62
NICKEL 4
MANGANESE Not Tested Not Tested Not Tested 1
SILVER
TITANIUM
POTASSIUM
BORON 43 15 23 38
SILICON 13 11 6 8
SODIUM 8 5 10 4
CALCIUM 1354 2517 860 970
MAGNESIUM 990 50 1171 1258
PHOSPHORUS 1185 1091 1070 1098
ZINC 1385 1254 1312 1309
BARIUM
SUS Viscosity @ 210°F Not Tested Not Tested Not Tested 77.3
cSt Viscosity @ 100°C 17.0 12.7 15.0 14.84
Flashpoint in °F Not Tested Not Tested Not Tested 420
Fuel %
Antifreeze % No No No 0.0
Water %
Insolubles % 1.6 0.5 0.3 0.1
TBN 7.0 6.1 7.2 8.3
Suggestions?
Code:
ALUMINUM 4 4 6 6
CHROMIUM 2
IRON 47 49 24 34
COPPER 4 3 4 14
LEAD 4 2 1 0
TIN 3 2 2 3
NICKEL 4
SILVER
TITANIUM
POTASSIUM
BORON 43 15 23 38
SILICON 13 11 6 8
SODIUM 8 5 10 4
BARIUM
Fuel %
Water %
TBN 7.0 6.1 7.2 8.3
