Originally Posted By: FordCapriDriver
+15F ( -9C ) is pretty cold to be using 20W-50, but it isn't cold enough i think to cause something like that, it could be the oil but it could also be what Jimzz says whcih is that he used a lower bypass pec than what it calls for?
20w-50 in Denver? I wouldn't even use it in Arizona.
The lower bypass spec should actually be better at protecting a filter from this kind of damage than the higher spec, but not in this case, obviously. The collapse, more than likely, happened over the course of several cold starts.
