Doing a LIM and head gaskets in a 04 impala with the 3400 and 304900 on the odo. After pulling the heads was extremely impressed by the condition of the cylinders and had to share. The owner is a customer of ours who runs a taxi service in town - this one sees the longer trips as well as in town. They got the car 30k ago and when I did the first inspection it has a jiffy lube sticker in the window. PO did 5k-7k on quick lube oil
Cylinders have just minor polishing up top where the rings stop and crosshatch the rest of the way down. No ring ridge at all and the rest of the engine just has minor varnish. 3/4 qt burn or so between changes (5-8k). Only issues found was PO or dealership put a ton of stop leak in this thing. Impressed it lasted 30k with how the LIM looked. HG was not leaking externally but cyl 1 failed leak down and was pressurizing the cooling system and LIM was leaking externally.
