Just received my first sample for my 2.7 Ecoboost.
This is my second OC on this engine, I am following the IOLM and the first OC was right at 10,000 mi.
Oil and filter was changed at the time of sampling with the same Citgo 5w-30 that was sampled.
9,925 mi. on sample
19,925 mi. total on truck
Citgo SuperGard SynBlend 5w-30 sampled and refilled sump with same at the time of sample.
Fe..............36
Cr...............1
Pb.............. Cu...............7
Sn.............. Al...............5
Ni.............. Ag.............. Ti.............. V...............
Si..............45
Na...............3
K...............
Mg..............18
Ca............1606
Ba.............. P..............574
Zn.............576
Mo..............33
B................6
Viscosity @100C..7.7
TBN..............1.9
No fuel, water, or coolant was present.
Analysis done by Fluid Analysis
Silicon is high, hoping thats still to be flushed assembly leftovers. Viscosity is a bit low, but all in all I am quite pleased with the report, and with the TBN at 1.9 I will continue to follow the IOLM.
9,925 mi. on sample
Fe..............36
Cr...............1
Si..............45
Na...............3
K...............
Mg..............18
Ca............1606
Zn.............576
Mo..............33
B................6
