This starts back in September of 2015 when I had my Indy mechanic putting a water pump on my high mileage Nissan Altima. He told me after working on the car the brake rotors were badly rusted and recommended replacement.
I checked them out through the steelies and they didn't look anymore rusty than what I would expect from old rotors in this area and they stopped good with zero vibration or noise so I left them alone and ordered some closeout parts off Rockauto.
I actually ended up getting some good parts on closeout I'll post the screen shot.
Fast forward to a few days ago I started getting the awful metallic grind when stopping so I knew it was time to see what's going on.
The drivers side had tons of meat left and fairly rusty everything. The clips were rusted pretty badly to the caliper, but nothing I didn't expect.
Here is the driver's side all put together.
The passenger side was a little different.
Yep that's the noise!
The inner bad was worn to metal but the outer had some left. Interesting enough the clips on the passenger side seemed much less rusty.
Here's the passenger side rotor
Here's both of the old ones next to one of the new ones.
Here's the passenger side all put together.
After I put it together I took it for a test drive. I thought it stopped good before but wow it will lock up the tires now.
