POE
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
tedonom, 01ws666, ariefnrst, tcoffin014, Schm1d
66657 Registered Users
97 registered members (ARB1977, 28oz, aquariuscsm, andyd, Audios, AnonOIl, 14 invisible), 1,889 guests, and 35 spiders.
Topics294,975
Posts4,925,212
Members66,657
Most Online2,553
Oct 27th, 2018
What Solvent to Remove High Temp RTV (Red) #4392200
04/29/17 12:24 PM
04/29/17 12:24 PM
D/FW Metroplex
The_Nuke Online content OP
The_Nuke  Online Content OP
D/FW Metroplex
Does anyone know of a good solvent I can use to remove cured High Temp RTV (Red)?
I used some of that stuff as an impromptu epoxy to mount an IAT sensor in an aftermarket CAI that didn't come with an IAT rubber grommet. Unfortunately, I now see that I oriented the sensor incorrectly and would like a Mulligan on my little jerry-rig. Successful removal of the sensor without effecting its operation (through incorrect solvent usage) is obviously going to be required before I can try it again, but I am not sure what I can use that isn't caustic or otherwise harmful to electronics and/or me.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.62 (215mm)
Re: What Solvent to Remove High Temp RTV (Red) [Re: The_Nuke] #4392207
04/29/17 12:43 PM
04/29/17 12:43 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: What Solvent to Remove High Temp RTV (Red) [Re: The_Nuke] #4392526
04/29/17 07:42 PM
04/29/17 07:42 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
RTV, unless specified for electronics, isn't ideal at the best of times. The acetic acid curing type is corrosive to current carrying metals. But with some parts it's OK because the electronic components are potted (embedded in an electronics-safe compound).
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: What Solvent to Remove High Temp RTV (Red) [Re: The_Nuke] #4420715
06/02/17 08:42 AM
06/02/17 08:42 AM
MN
ironman_gq Offline
ironman_gq  Offline
MN
elbow grease is the safest method. Cut as much off as you can and them peel and scrape the rest off. Red is pretty resistant to most solvents and anything that will dissolve it is going to damage the sensor.
