Originally Posted By: rrounds
I'm building a buggy with a dual remote oil filter set up. The one thing they will need is a by-pass in the filter, don't care what psi the by-pass is set at because with two, I don't know if they will ever see by-pass.
Rod, I honestly think dual XG8A will be MORE than enough for any situation, especially a buggy.
You can get a case of six on ebay for $24.
With some thread adapters (also on ebay) you can run dual XG3976A if you are REALLY OCD about all this.
But dual XG8A's can handle the flow of even the wildest big block engines and will never go into bypass.
Hey, if you want to go REALLY unique, copy the 3-4 filter set-up on the huge Cat and Cummins V-12's and V-16's. Each filter holds about a gallon of oil!
