Originally Posted By: SargeBB
Mystik JT-6 Hi-Temp. LC #2 or Chevron Delo EP LC #2. The only difference is that the Mystik uses a high viscosity base oil and the Delo's base is mid-vis. The 'sponge' is NLGI grade 2 Lithium Complex on both.
I'm with SargeBB. His choices are awesome, but I'll pick the Delo first, and the Mystik will be my backup. You can't go wrong with either.
