Subject is a Craftsman 358.794750 2 cycle gas powered blower.
Filled up with fuel for the first usage of the year. Started it up. It ran about 30 seconds until it died.
Checked for spark. None present. Replaced plug. Then discovered that it was not getting fuel. Removed carb and cleaned it. Upon further inspection, noted that the fuel line in the tank had totally disintegrated to the point that the fuel filter was rattling in the tank. Totally replaced all fuel line.
Put fuel in the tank and hit the primer bulb. The bulb sucked in gas but still stayed depressed. Went to start blower and it fired right up. Used with no issues but bulb stayed depressed unless manipulated to pop out.
While I am happy that I actually cleaned a carb, put it back together and I'm not shopping for a replacement blower, I am curious as how to correct this issue. Thanks in advance for any help.
