ciera drivers widow guide
That should be at the top rear edge, if it is worn out you should be able to just put the new one on and tilt the window back into position. Hard to explain easy to do...
Thanks! I'd rather not take the door panel off. I just have to somehow pick the old guide out of the track with needle nose pliers or something.
