Got a quick question:
I am doing a custom exhaust install on an older car (1981 MB 380SL). The exhaust system did not have a bung for an O2 sensor so I have to put one on. The bung I got seems a little deep. Therefore the sensor will be shallow in the pipe. As you can see in the picture with the sensor in the bung, the sensor is not fully deep. Does anyone think this could be a problem or cause a false reading creating mixture issues? I can always turn the bung down on a lathe if needed.
Thanks in advance
Thanks in advance
