Living in the rust belt (but not from it) I am learning the hard way about rust. I have a 2003 F-150 that I primarily drive in the winter and rust is getting to it. Not worth a whole lot so I am not going to properly fix any cosmetic damange, but sparked an idea for preventing rust. I used this formula below last year and so far so good.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2043211
So the question is could polymerized vegetable oil work as well? Similar to why seasoned cast iron pans don't rust since there is a layer of sticky polymerized oil. Being sticky I would think its hard to wash off and with a low viscosity it can seep into every crevice. Only problem is how to polymerize it without heat.
Thoughts?
Thoughts?
