Originally Posted By: i_hate_autofraud
To me an oil that goes dirty that fast is because dirty oil was still in the engine.
In a case like this I’ve done an engine oil flush by adding 2 cups of kerosene to a hot
idling engine and let idle for 15 minutes, then stop and change oil and filter. (old trucker trick)
Drain and allow oil to drip out for 10 minutes. Shops like to get the oil plug back in
asap to push a car thru the shop. Draining for 10 minutes or more lets 2-3 cups of oil to
fully drain that usually stays in the engine!
If after that, the oil turns dark in 2K then I’d take an oil sample for UOA and see what’s
in there at 5K.
In the cars I’ve tested and used Filtermags later, the dark oil was ferrous wear metals, lead
and aluminum that turned the oil dark! I run full synthetic and a pair of FilterMags and have
visibly clean oil for 6 months or so / 7,000 miles! It’s key to be sure you have clearance all
the way around the filter to mount the FilterMags and not hit the engine block, etc.
When FilterMags reduce ferrous metals, then all the other metals drop too! I wish I thought of it
years ago! I’ve not seem high levels of carbon in the oil, the only way for that to happen is have
massive amounts of piston blow-by which means a piston ring problem.
If you have a spin-on oil filter instead of a filter cartridge, check out PDF with some good Pics:
FILTERMAG vs HOMEBREW
https://app.box.com/s/uxvu8dmscf5wcgftutdm0ejqwgn86tw7
DI engines create more blowby and fuel dilution than port injected engines is why the oil gets dirty fast. Nothing you can do to prevent it. Like how most diesels the oil is pitch black after you start it up after an oil change. Oil color doesn't tell you anything about it's condition or how well it's doing it's job, UOA's do.
OP, Pennzoil Platinum is a great oil, but your oil would look like that with anything. It's just the nature of DI engines and is normal to see them dirty the oil quick.
