Originally Posted By: ChrisD46
How on earth will a 0W16 (or below) ever meet a hot weather temperature spec of say 100 degrees F. ?
Originally Posted By: FordCapriDriver
How much thinner can it get? I mean for how long is this trend of reducing viscosity going to continue?
I don't think it will be a problem. Synthetic oils will keep getting stronger and better. Engine efficiency will keep getting better as long as the combustion engine will still be mass produced (probably won't last much beyond maybe another 10-20 years max)
I can see future engines coming out using Koenigsegg's Camless Engine technology, thus further reducing the need for oil as lubrication. Oil will only be needed to Lube the Crank and pistons, so it won't be working hard at all, if you think about it.
