Originally Posted By: y_p_w
Originally Posted By: d00df00d
Apparently the armored version only weighs around 300 lbs more than a regular 750iL.
Normal E38 7-Series cars drive quite well though, from what I hear.
What I love most about them is that it's easy to swap manual transmissions into them. All the engine options -- including the V12 -- were available with manual transmissions in other BMWs, so the most important bits bolt right up. You don't even have to fab up interior trim parts because the E38 was available with a stick in other markets (with smaller engine options). That means you can do the swap mostly (entirely?) with factory parts, right down to the ECU software. When you're done, you can enjoy the engine of your choice (I6, V8, V12) with a clutch pedal and real shifter, and your passengers can enjoy a high level of luxury. And when it's just you in the car, it's surprisingly satisfying on a back road for a 2-ton car, especially of that vintage.
I've always had some desire for a 2001 750iL 6MT with a few choice performance bits. Maybe one day, for lols...
How well armored? I heard that possibly the ultimate factory-made armored vehicle is the Mercedes-Benz S600 Guard, which weighs about 9200 lbs, which is about 4000 lbs more than the base S600. And that doesn't even include a smoke machine or missiles.
Not sure how it compares to the S600 Guard. I know it's designed to take small arms fire and light explosives. Apparently a lot of the armor is aramid, which for what that's worth.
Gun and explosive testing starts at 2:13 here:
Also, there's this story about a previous-generation (E32) armored 7-Series taking sniper fire in Iraq:
http://www.thetruthaboutcars.com/2016/11...is-sniper-fire/
There seem to be multiple protection levels for this kind of car. I'm reading that the S-Class Guard has been offered with multiple levels. Maybe the numbers you saw were for one of the heavier versions, whereas the E38 750iL Protection was only offered with one of the lighter types.
