I'm burning about a half quart every week or two. I replaced the PCV valve and have been told the culprit is most likely the valves are leaking oil. Any suggestions on an additive I can use that will help reseal the valves and stop the oil burning? There is no oil on my garage floor but the car doesn't smoke either. It runs fine but would like to minimize the oil consumption.
