Originally Posted By: UncleDave
Originally Posted By: Donald
I am not sure how beneficial a microGreen filter is. The bypass part will reduce the contaminants somewhat, but it cannot help with depleted additives which will result in a low TBN. Nor will the filter help with a oxidized oil, change in viscosity.
The only situations I have come across where the TBN is still ok after 10K miles are pickup diesel engines with sumps that are 12 to 14 qts.
The way it
seems to work is that a buildup of smaller particles under the filters threshold contributes to TBN depletion, and removing these particles extend the life of TBN significantly because it doesn't have consume itself to keep the particles suspended.
This is why bypass filters extend sump life far beyond the capacity increase they provide.
I haven't seen any strong evidence the smaller particles help cause TBN depletion, although it might partially happen.
There was a fleet study done on Chevy V8 Tahoes back in 2005 which used excellent bypass filtration, but TBN was still a problem. ( See
https://avt.inl.gov/sites/default/files/pdf/oilbypass/oilbypassfinalreport.pdf )
"Degraded TBN followed by out-of-specification viscosity levels were the two predominate failure modes of the Tahoe oil."
TBN decrease is caused by sulphuric & carbonic acids countered by the buffers in oil. To some extent, these acids could be formed from some of the 2 to 10 micron sized soot particles (bypass & microgreen range) in some way unknown to me.
Anyway, the fleet tests show bypass filtration similar to MicroGreen's parallel method do
something to increase longevity.
Fuel dilution is what could really ruin the 30,000 mile oil change interval party. Too much heat on weak base oils causes oxidation as anti-oxidants get depleted too. Engines survive, though may get stuck rings or sludge if taken too far. A risk.
