Hi guys,
I've had my rear brake calipers media blasted and they came back in a very light color similar to aluminum.
I've never seen brake calipers that color and came to the conclusion that they must be coated with something from factory against corrosion - Would I be correct?
I plan on painting them in high heat paint, is this enough protection for them?
They are just stock caliper and not difficult to get a hold of or anything so if they require special coating then it isn't worth the time/cost
