Originally Posted By: HosteenJorje
Originally Posted By: kschachn
Originally Posted By: i_hate_autofraud
If going into an aluminum cyclinder head, I always use anti-seize paste and reduce torque.
Bone dry threads 5 years later are likely seize, gall and strip-out next time!!
Yeah, I used to think that too until I got my Toyotas. The replacement NGK plugs always said not to use anti-sieze so I never have, and it's been a long time later and they've always come out OK. No seizing, galling nor stripping. Same for my Accord, but those don't go as long as the Toyota ones do.
Those long-life iridium plugs are manufactured with a tin plating on the threads to facilitate removal after extended use. Hope the plugs in my 04 Camry come out easy as they are the OEM plugs.
Tin? It's trivalent plating, which is basically chrome. All plugs from NGK or Denso have that type of plating.
