I bought a Stihl FS-91 trimmer which has a 4 stroke, 4 mix engine (you mix the oil with the gas). According to the users manual you should avoid using the unit at full throttle for the first 3 tanks of fuel, The unit has a rev limiter which it will hit at 3/4 throttle with no load on the machine and with the torque of it I would imagine you would only need full throttle in really heavy grass or brush.
The unit was started by the dealer and he warmed it up and ran it a bit to make sure it was good, I have started it up and ran it thru a few heat cycles thus far under no load, I ran it between 1/4 to 5/8 throttle and alternated RPM.
Any other tips?
Any other tips?
